cleaningfool
- Joined
- Jan 17, 2008
- Messages
- 76
I will be doing my first encap job on friday in a nursing home. Any advice would be appreciated. Do any of you vac after encapping, or do you let the custy do it? Thanks Mike
cleaningfool said:Thanks for the reply's. Is prochems a good choice for encapping. It is one of two encapsulation products on the shelf at my distributor. Thanks again Mike
scottw said:Rick G's Release It really brought encap to the attention of most cleaners. It is a fine product and continues to be an industry leader. That is the standard we set out to beat when developing Encapuclean Green DS. We think we reached that goal. Obviously Rick and many of his loyal customers might not agree.
encapman said:As Scott mentioned - it's good to compare "encap" products. Excellent advice! Don't blindly believe the marketing hype or be coaxed into assuming that a so called encap product encapsulates soil - just because it says "encap" on the label. Here are a few simple tests you can perform to get a better idea of how the product will perform...
First - dry a tablespoon of the detergent in a saucer and compare what you find after it dries. Does it dry to a brittle crystalline structure that flakes away from the dish? Or does it stick to the dish like Smuckers jelly? The polymer is the vehicle that captures soil, holds the soil in suspension, and releases the soil during post-vacuuming.
Next - clean some dirty carpet with the product. How does it perform? Is it effective on a wide range of soil conditions?
Lastly - test the products that your comparing side by side on a carpet sample. Place the sample in a high traffic area for a few days and walk on it. Then carefully evaluate the carpet sample to see which section stayed the cleanest.
This simple testing can help you gain a clearer idea of how the product will perform in the real world.
scottw said:I agree with Rick's suggestions for real world testing. Clean some carpet with the encap products you are considering. Do several side by side comparisons. Different products have different strengths and weakness. Several jobs should give you a well rounded idea of what you lie or don't like about each product.
I don't agree with the simplistic dish testing. This has neither the realism of testing on a dirty job or the science of laboratory testing.
The way a product dries in its concentrated form will not be the same as how it performs when diluted. The way a product performs in the presence of soil on carpet fiber will be different than what happens on a clean dish.
The dish test is essentially a good marketing gimmick.
A more telling third test would be to compare resoil rates in some of the places you do a side by side comparison. Check after one week, two weeks, a month or longer.
