Scott S.
- Joined
- Feb 3, 2008
- Messages
- 3,252
- Name
- Scott
So, your picture, is that at the dilltion rate that you applied it in the dish? crystals form better and faster when in a concentrated form. like a salt solution in a glass of water left to dry it makes some awesome looking crystals. but put just a little in what does it look like then, just a light frosting. crystals are easier to remove the larger they are but how about when they are small. When i was in school we did alot of experiments on crystals and this is why i ask this.
seems to me you would have to do a cleaning with the encap on a brand new pc of carpet, then let it dry completely (maybe for a day) then vac and see what comes out. that way any powder you get would be encap, but you would need to measure out the amount of concentrate you use, let it dry like marty did in his dishs, then weigh it. then vac the new carpet that had the encap treatment (making sure when you used the encap on the new carpet that you used exactly the same weight of liquid from the same container) and weight the amount of powder (if any) that you get. a new vac would be recommended for this test so there is not any contamination.
