sam gm said:
eric, The new 15 attachment looks nice, how has your testing gone so far with it? Will the new head attach to the junior handle? Hows the vac at the head since theres more air flow?
Would it be an option to engrave a custom company name.
thanks
We used it the last 2 days and it's absolutely incredible. It actually more manuverable than the 13". I thinks it's due to where the balance of the weight is a little different in the head.
The head is very easily interchangeable by removing the one adjustment screw in the back of the handle. It will slide right off. But, I wouldn't suggest buying just the head because the head is the majority of the cost and you would only have one unit.
I haven't ran it on a small blower yet, but with your 8,000 Q
Vortex, you surely wouldn't have a thproblem with air flow. Both units use a common lid, so the attic space is the same in both units. Unlike the original Zipper that required more air flow and lift. Also, as you know from the Zipper Jr., both vacuum ports pull evenly due to the placement of the vacuum flange.
We will not be offering custom engraving due to the complexity of fixturing the product for final machining.
Also, we re-engineered the vacuum flange on the back of the handle to have a swivel or to lock right or left.
