Engine question.
adamh
Adam Hale
Engine question.
I have a 25 horse liquid cooled Kohler motor. Now that its summer it gets really hot in the van. I was wanting to run a fan off the battery to cool the belts and run more air over the engine. The fan I am looking at will pull 20amps. Is the little alternator off that Kohler going to keep up? I also run a pump in off the battery.
Adam
Ross Buettner
Ross Buettner
Ghetto fix:
Run a hose from the intake of your air filter and run it outside the van.
20 amps is a lot of power even at 12v. You need to find out what the alternator on the kohler is rated for in amps.
dgardner
Dan Gardner
Is your engine an LH685 ? Looks like you have a 15A alternator, and you need some of that to charge the battery and run the pump. Not going to be much left over for a fan I'm afraid...
Sent from my ADR6300 using Tapatalk
Shane T
Shane Tiegs
I just went out put an amp meter on one of them. It pulled 2.6 amps.
