engine trouble
i was driving down the road and the engine light came on and the truck went to idle. i puttered to the grass at 1 mile an hour. i turned it off and back on and the problem disappeared, except the light stayed on. the light eventually went off.any ideas ? 2006 izuzu npr. diesel
gene
could be a hand full of things.....but the first thing I would check is the sediment filter....
Goomer
Frank Mendo
The computer should have saved the error code in it's history if you can get it read somewhere.
I replaced the sediment filter already and it was full of gunk. the dealer charges 95 to read it. i will try sat if i get the time.
gene
some of that "gunk" could of found its way to one of the injectors and made it sputter a bit....change your fuel filter and put a diesel injector cleaner in your tank...
KevinL
Kevin Leach
Do you have an auto parts store that will read your code for free?
ascrubabove
The most common problem that would cause that would be some air was sucked into the fuel system, and the most common place that happens is the sediment filter. The second most common problem would be the lift pump, it supplies fuel from the tank to the governer.
the problem has completely disappeared. the truck never miss a beat it just went to idle . Shutting off the engine reset the computer and it was fine except for the check engine light. my sediment filter has a light that comes on in case of water, but it never lit. i'll look to see if i can hook to the link but i'll bet it's different .
gene
i wonder if the OBD tools auto parts stores have would read it??
I agree it sounds like something broke loose and clogged the injector just enough
Newman
Chris Newman
Do those trucks have OBD II diagnostics? If so the code scanners have come way down in price. For under $200, mine will read every domestic and foreign car and van sold in America - not sure about the trucks.
Chris I have the code scanner but i forgot to look at the truck for the link. I'll look on Monday to see if it fits. the code should be stored.
gene
