If it is not too bad, you can use some quality stainless cleaner or wd40 and some 000 steel wool. Try a small area first, and make sure it is causing no further damage. Slowly work it out with the steel wool scrubbing (gently) with the grain. Scrub a little, then wipe it off and see how it looks. The biggest thing is to go WITH the grain.
