Brian R
- Joined
- Jun 13, 2008
- Messages
- 19,945
- Name
- Brian Robison
Ok, I am a new member (first post) and have been reading about the 2" Evolution Wand here just trying to get some input. I purchased one and have been using it for about 2 month and so far so good. Some of the problems listed so far are pretty acurate but here is my take on things and I would like to see if any minds have changed since the last time this subject came up.
First of all, overall, I like it. Best wand I have ever used. Only have been Steam Cleaning for 6 or 7 years because I was a Chem-Bri Guy for the first 10 years of my miserable carpet cleaning life. Much better now.
The jets need to be changed on the ends just like what was said but I wanted to give the manufacturer the benifit of the doubt. The way around this is to lift the side of the wand nearest the edge and spray and then extract. The 2" suction power is more than enough to pull light soil and any debris. I'm using the commander HO. Not the right way to do it but works when needed.
Cleans way quicker and easier than my 1 1/2" with a glide. Some chatter on CGD but no more than my teflon glide. I did an 11,000 sqft job that I do every 6 months and it cut off about an hour or so and I was sick as a dog doing it. We'll see next time.
Carpet seams dryer after
Super light which is great, but if you don't prespray residential(which I do but tried it without) it won't get down in the fibers as far as the suction goes. Unless you do another pass after wetting or lean on it a little.
I'm always afraid I'm gonna break it but haven't yet even after a couple of drops and bumps.
I think the glide needs slits on either side to help with airflow because I am steaming up a little with 500lbs. Don't want to mess with it yet. It's doing pretty well so far.
All in all I am cutting alot of time and fatigue off of each job and what else do you need? Yea it needs a splash gaurd and a longer jet tube to cover the 16" area but it hasn't caused much of a problem. I think it covers a little more than the 11" that was said earlier. Some things hard to get under but again, not much of a problem.
I give it a good rating but the price could stand to come down a bit.
Let me know what you think and if I can think of anything else, I will post it.
Thanks for your help so far.
