Re: Explain why you use ? Pressue.
rstrick said:
ok here is your system? really mine but for my education purpose.
Wand
1.5 wand
two jet
4 flow
Boxxer 421
1.5 whip X 8' 2'' hose to the TM
ok I know there are more quality wands its what I have for now. no need in point and laugh session at my stick. Ill up grade later. have to build the biz first then buy more toys.
lets just say we are working on cut pile nylon. nothing special.
if it's an AW29 wand, there's not a darn thing wrong with that wand.
It's actually a very good cleaning wand..light, nible and easy to throw around.
and don't let the board deJour designer wand users tell you any different ...cause they don't know squat if they say otherwise
It does have some limitations that can get you in trouble though.
It will over wet the backing at high PSI and it's not a "forever" wand..meaning it won't last 20-30+ years like a
Prochem wand
I'd recommend you dump the 1.5 whip...they make cuffs for 2" hose and 1.5" wands.
Use the 1.5" whip for upl cleaning
Bump up the wand jetting to 06 flow.
You don't need anymore with that wand.
(fire hose flow is another board deJour phenomenon started by a salesman .... who never cleaned very many carpets to begin with)
"some" increased flow is better, but a lot of guys have went off the deep end IMO.
There IS a point of diminishing returns where you're just wasting tons more water for very little gain.
06 flow is a good spot for your wand.
keep the psi 350 and under ..that's where the AW29 shines best.
anymore psi than that, and you're injecting the backing with water.
When we ran AW29's, we had two .
One with 04 jetting for quick dry times on light soiled res and the 06 for heavy soil and empties .
for $200 to $250 you can have another AW29 and do the same .
You "should" have a back up wand on your van anyway.
Cover the vac port on the TM and set the vac relief valve on your Boxer to 14hg.
Keep your bower filters clean.
take two empty apts and call me in the morning....
Dr meAt
