Favorite spotters..........
Goomer
Frank Mendo
While encapping......NOT HWE'ing.
Are you strictly limited to encap spotters only???
Steamin McFadden
Go to vacaway web site, get the free sample kit, you will get one small size of each spotter, they are made to be used with vlm cleaning. He even has an encaping citrus gel. SPot n Boost will work on just about anything, need plenty of cotton rags to blot with.
Hel gel, spot n boost, problem be gone, and red vanish are all you need, will handle just about any spot you come across.
encapman
Rick Gelinas
Encap-Spot is a great all around Encap Spotter. Works on a wide range of spots, and doesn't require rinsing.
In fact on the no-rinse side, if you had a really tough stain that required a heavy duty standalone treatment such as Red Relief, or Rustaway...You could use the specialty spotter first, and then blot up that specialty spotter with a towel. Then you could follow that up by dousing the spot with Encap-Spot and blot that with a towel. The Encap-Spot becomes your rinse step and it doesn't require further rinsing. We've nicknamed it "An Extractor In A Bottle".
