John is right, plenty of vacuuming. The powder is very fine. Use a HEPA or ULPA vacuum system or there will be dust everywhere. You can use the truckmount with a Dust Downer if you are careful that all connections are tight. You don't want to spread the powder. Don't use brush agitation.
John is also right on using a filtration soil remover, but I prefer Bridgepoint's Filter Free.
A product to remove artificial dye can help on the powder that did get work. Treat it like tiny spots of Kool Aid or Gatorade. Use Red Releif or Red ZONE. If you use Red ZONE you should not need a steamer if the carpet was protected. But for carpet without sufficinet protector, you will need a steamer or an iron and white towel.
