Fire hydrant to garden hose connector
Just in case..
do you carry the 600ft of garden hose run to across the street and down the block
and the bigazz wrench too?
It’s called a spanner
it's not a normal spanner
(they won't work due to 5 sided nuts specific to hydrant and curb box water mains )
needs to be a hydrant wrench ...and the bigger the better
Show us a vid of how to attach and turn the water on
Reactions: Dolly Llama
You will need to have a permit from the water company which should include a water meter on the set-up; otherwise, you are stealing water.
I use to have such a set-up.
you don't have to open the valve all the way
....unless you need 500-1500 gpm flow
If I can understand this,
They're not high PSI, just mega flow rate
appears the PSI isn't all that great and wouldn't burst a garden hose
(fire truck pumps is what boosts the PSI)
donno if many CC'ing jobs would be worth the PITA though.
"Is there water anywhere in the facility?
OK, lemmie know when there is"
Nope, that'd sure burst my 3/8" air hose that I use to fill my tank
Never done it
I just want to know why doing it would indicate a bad “business model”?
