Five minutes with the Fabulous Ricky G
So Rick..
-What year did you start the encAp crAze and how has the industry? Or has it?
-What is the maximum amount of cleanings that a ground floor heavily used commercial establishment can take before it needs a good ol' fashion HWE?
-Would you say Releasit is the 1st, 2nd or 3rd best selling Encapsulating Shampoo on the market?
-And if your company ran out of it what product would you use on your accounts?
-Is the Cimex still the best scrub and run machine available?
-What is the best detergent to rinse Encap impacted carpets with?
-Where do you see Excellent Supply Co in five years?
-How long would it take to "Cimex" 1000 sf of empty room/ moderately soiled CGD and how long would it take to OP the same carpet with cotton pads and keep going til the pads come up clean?
-Who is your biggest competitor in equipment and juice sales?
-How big or small is your cleaning biz and how often to do you get your hands dirty?
Thanks!
daniel@procarpet
Seriously how often do you have to change out the little pads on the cimex? To me it looks like you would be constantly switching pads.
Shorty
Shorty Glanville
Roughly every $700.00 worth of carpet cleaning, depending.
On big runs, they last longer, you may make $850.00 - $900.00
On some jobs you may only make $500.00 or so.
Different operators will get different results, this also applies to the carpet fibre & style.
You also get different results with the beige, compared to the grey pads.
Sort of like, how long does it take to get me drunk on a Saturday night after I've had a big feed.
The profit far outweighs the expense. :wink:
Ooroo,
:roll:
encapman
Rick Gelinas
Hey Mike. Thanks for asking.
The Encap Craze - LOL. A few years back I was the first guy to coin the phrase “ENCAPSULATION”. That was somewhere back around 2001/2002. Whittaker had been out there with their Crystal Dry product prior to that time and it was, and still is, a good product. And DuPont had also recently introduced their Resistech product. But no one had yet used the term “encapsulation” to describe the process. When I started talking about this new way of cleaning on the message boards, I was trying to come up with a way to describe the process and I thought that the word “encapsulation” was a good way to explain it. So as far as I know, I was the first person to use the word “encapsulation” in this context. And I guess I probably should have trademarked the word - because it really caught on in the industry. I’d be rich. :wink:
That depends on the level of traffic, the degree of soil, and the frequency and the quality of the encap program. If a (a ground floor heavily used commercial establishment) building like you’re describing gets set up with a good regular encap maintenance program, HWE cleanings can be kept to a minimum. As a professional cleaner you should regularly inspect the carpet to evaluate the condition of the carpet. And then implement a thorough HWE flushing whenever you see any significant level of soil build up in the carpet. As a general rule of thumb you might plan for an annual HWE cleaning. However adjustments could be made according to wear, traffic level, soiling conditions, and the level of encap cleaning that you’re providing.
Of course I believe Releasit is the BEST product on the market. There are a few reasons why I feel that is true. (1) The cleaning ability of Releasit is extremely good. We use a very strong surfactant blend that is highly effective on heavy commercial soil conditions. (2) Beyond Releasit’s cleaning ability - another KEY reason why Releasit stands out is its polymeric base. We load Releasit with polymer. Releasit contains a higher level of polymer solids. And the type of polymer that we’re using is unique too. Our polymer is an oil loving polymer. It resists re-soiling. And since we bulk Releasit with so much polymer it has a sufficient polymer density to hold soil in suspension until the soil can be extracted during the normal routine of post vacuuming. (3) Releasit also contains a fluoro-chemical that adds a measure of soil resistance to the cleaning and helps the polymer to release more readily from the fiber.
If our cleaning company ran out of Releasit? We’d have to reschedule the job.
Yeah, I think it is. The Cimex is a burly machine that can easily clip along cleaning 2,000+ sq ft per hour. With a 6.6 gallon tank it makes light work out of commercial carpet care. The 3 head design is easy to operate and the planetary scrubbing action provides deep agitation to commercial carpet fiber. For serious commercial cleaning I still like the Cimex best.
Releasit Encap-Punch is a great product for HWE cleaning. It contains the same polymer that’s in our shampoo product (Encap-CLean DS). And for a hot water extraction detergent, Encap-Punch brings the added benefit to the table of NOT leaving a residue in the carpet that could attract soil. Any residue that remains in the carpet will actually dry to a brittle residue that can be vacuumed out of the carpet following the HWE cleaning.
Excellent Supply has continued to grow every year since we started the company. We enjoy our place in the industry. We are in a position to help guys become more effective at commercial carpet care. We’ve been doing this for the past few years and we hope to be doing it for many years to come.
-How long would it take to "Cimex" 1000 sf of empty room/ moderately soiled CGD and how long would it take to OP the same carpet with cotton pads and keep going till the pads come up clean?
It would take roughly 1/2 an hour to clean 1,000 sq ft. I’ll let the OP specialists address your question about OP cleaning.
JonDon and Interlink are the largest equipment suppliers in the industry and they do a good job of providing everything a typical carpet cleaner might want to purchase. Excellent Supply provides commercial cleaning supplies exclusively for cleaners needing products for commercial carpet care. So we’re on a different path. I don’t know that we have a single biggest competitor for juice. There are a lot of chemical & supply companies that have now jumped onto the encap band wagon. A few of the competitors have some decent products, and there are a number of products that aren’t quite ready for prime time. Releasit continues to stack up well in the market. It seems like we’re always the one that the other companies compare themselves to - so we consider that an indirect complement to our reputation as a leader in the industry.
Our cleaning company “KleenStep” is still going. I have to admit I haven’t given KleenStep as much attention during the last few years, as we’ve been primarily focused on developing Releasit and Excellent Supply. However we still have several regular monthly accounts that we service. I didn’t want to let KleenStep just die on the vine - it’s still a solid brand with a registered trademark and a long history of service in the Tampa Bay area (I started my cleaning business in 1982). So I’ve just recently purchased a new van for KleenStep and we’re getting a wrap on it (see image below). We are going to be stepping up the marketing for KleenStep once again. I still love cleaning! I guess it’s in my blood. I don’t get out and clean as often as I used to, but I still manage to get out and do an occasional job. I have a really good technician named Ryan who has been with me for a few years now. Ryan is the person who handles most of KleenStep’s cleaning jobs these days.
Do you think those Transports can handle the weight of a Cimex?
Thanks Rick!
See ya in Nashville.
encapman
Rick Gelinas
The Ford Transit Connect is rated for 1600 pounds of payload (that's 3/4 of a ton of cargo payload). So it's capable of hauling a full load of cleaning equipment.
We have our Transit Connect loaded with a Cimex, an X-Vac pile lifter, a high speed floor burnisher, a wet-vac, a mop bucket, a cart with buckets etc, 12 gallons of chemicals, and a few other small items. We have it set up for carpet cleaning and VCT floor care. When we need to throw in a portable extractor, we just have to swap out the high speed burnisher.
Even fully loaded the Transit Connect still rides as smooth as it does when it's empty. I LOVE this little cargo hauler. It's perfect for a commercial cleaning set up. You'll get to see it at MikeFest.
Bob Savage
Bob Savage
Great looking van Rick. I can see a nice compact truckmount inside that rig. ...lol
See you in Nashville. Is Nancy going to be there too?
encapman
Rick Gelinas
Nope, I'll be there with Drew from our office.
Albert Lazo said:
Wow, cool looking design. Who did it Rick?.
Thanks Albert! It's not quite finished yet; that was just a "design draft". The wrap installer is planning to install the final version this coming week if the weather is warm enough. Here's the company that I went with for the wrap... http://www.voodoowraps.com
H
Heathrow
Hey Rick - I'm half way through a great book by Jack Canfield and Mark Victor Hansen called The Aladdin Factor - saw your letter in it. Do you know those guys?
Excellent book, highly recommend it.
encapman
Rick Gelinas
Wow, it's funny that you ran across that quote. That quote is actually from my dad. I'm Rick Gelinas Jr. My dad is the educated one. He has a PHD. He was a psychologist for many years. He and his second wife Linda headed a non-profit organization helping "lost cause" "throw away" children, before they slip through the cracks in the school systems. He's retired now and is currently passing the days doing his writing, making wine, and cabinetry.
My dad has a lot of drive and creative energy. He always encouraged me to pursue entrepreneurial goals. I give him a lot of the credit for helping me to develop a passion for business, marketing, and thinking outside the box. He's a pretty interesting guy.
