Flex Fire prespray..........?
Alright, I've seen the banner and watched the video........... When did this come out, any more info on it and any sample packets?
@Scott W
Tom Forsythe
Flex Fire completes the trilogy of powdered formulas for cleaning carpet we envisioned a few years ago. Flex Powder with Citrus Solv (pre-spray) rinsed with Fire or Ice. Choose Flex Fire whenever you are facing a carpet that is loaded with grease and/or in full restoration mode. The goal is to get it clean with all of the cleaning power available. It is also handy when you have carpet that can be satisfactorily cleaned with a rinse only. Choose Flex Ice when the combination of Flex Powder as the pre-spray and the heat of your truckmount does not need extra alkaline cleaning power to get the job done. If you clean a lot pH sensitive fibers like upholstery then you have the added convenience of not having to switch emulsifiers.
We do not package our products in sample sizes. I had plenty of those 2 ounce bottles and bags in my shop that I had picked up at samples at trade shows. Usually not enough to do a job let along try the product on several different jobs to get to know its strengths and/or weaknesses.
We do give a 100% money back guarantee on all Bridgepoint branded chemicals including new Flex Fire. Pick-up a gallon. Give it a real test. Put it through the paces. If you decide it is not for you, bring it back for a refund.
