boazcan
This is off the AT waste tank. The lower float to activate the pump out. I had to replace it last year because the switch was not working. This is the number on the switch with pictures of it.
http://www.google.com/search?gcx=c&q=v7 ... tweApNDjDg
These are pictures of the actual switch with the "magnet" piece added on to the level. I think that add on piece to level is causing it wear prematurely because of the weight of the magnets. Is this similar to what any one has seen when they take it apart to replace.
Should just buy a couple and keep around to change out when necessary? Or I was thinking of buying one smaller more powerful magnet to keep the weight down so that it doesn't wear the guts of the switch out.
Anyone play with these before? I am not buying any more $180 float assemblies.
