Duane Oxley
Moon Unit
I thought I'd let you guys know about the FloodMaster systems I've designed. Basically, they're dedicated flood- suckers. And they're only 20 inches wide by 48 inches long, so they're super- compact.
What makes them unique is the attention to ruggedness and quietness, and the fact that they never fill up. Ruggedness comes from the larger- than- necessary motor to blower sizing and the coupler sizing.
They feature 22 HP Kohler Command PRO engines with a #36 blower, or a 25 HP Kohler, with a #45 blower.
Both systems utilize a #8 coupling, for added durability.
They're plumbed to accept 2.5" hose, and can be conveniently reduced to 2". (A "four to the door" version is also in the works.)
And they have two silencers- one for the motor and one for the blower. The blower silencer is designed to be installed under the truck, which allows for a large silencer and for extra noise dampening, which is great for those late night flood calls, without disturbing the neighbors.
They're continuous pump out systems, so they never fill up. And they come with the UltraFlow filter, which has the benefit of zero interference with airflow and a large trash capacity of approximately 3 gallons.
Simply put, they're powerful, quiet, fit well in a van and leave plenty of room for other equipment.
