gimmeagig
- Joined
- Mar 25, 2007
- Messages
- 744
- Name
- Roxy
I'm always wondering if my flow meter is working the way it should. The other day I did a job and I set the flow at 3 gph. Halfway into the job I checked the content of the 5 gal solution jug and it wasn't visibly emptier.So I upped the mixture to get more rinsing solution into the water.It made a little bit of difference.I check the ratio with the mix tank empty and get a solid reading while it refills.So when I can see the little ball float and stay around 3 or 4 gph that must mean that the solution gets into the mix tank,right? The adjustment is very touchy. 1/16th of a turn and I'm already at 4 gph. Is this normal? Is it possible that the meter shows flow but is inaccurate?
So at 4 gph how many normal sized homes should I be able to do with one 5 gal jug?
I'm not very busy yet and I'm wondering if I should not use a smaller jug so that I don't have so much solution left over.I hesitate to use old solution because I'm not sure if once mixed, the solution has a limited shelf life.
How long can I store premixed solution before it goes bad?
And if it does not loose it's effectiveness, I could save time and the trouble of mixing the stuff on location by having a few 1 gal jugs premixed. Some basic solutions to which I could add a few extra goodies depending on the job. Does that sound like a good idea?
