Joel D
Why does foam hurt a blower? Ive had a few times that suction was reduced briefly after extracting a detergent spill or something. But how does that hurt two big chunks of steal?
Joel D said:Why does foam hurt a blower? Ive had a few times that suction was reduced briefly after extracting a detergent spill or something. But how does that hurt two big chunks of steal?
tman7 said:Someone suggested to me that running diesel fuel through the lube port of a blower can clean corrosion out. Is this true?
AshleyMckendree said:tman7 said:Someone suggested to me that running diesel fuel through the lube port of a blower can clean corrosion out. Is this true?
I run 1/2 cup of kerosene or diesel through my blower every few months.
Jim Martin said:tman7 said:Someone suggested to me that running diesel fuel through the lube port of a blower can clean corrosion out. Is this true?
sure........when your are picking up all the shrapnel from when it grenades you will notice how clean all the pieces are from having all the shit blown off of them................
at the end of each day job just let your blower sit at an idle while you are rolling all your hoses up and it will dry itself out.....at the end of the day lube the port with wd40 what ever you like.......change the oil and/or grease as recommended and you will not have any problems to worry about.....
Dirk said:I'm with greenie on the whole blower thing. Those fuggers are hard to break.
meAt said:the foam in the hoses causes the lose of air flow.
Not exactly sure why, maybe one of the smart peeps here could explain the dynamics of how/why.
i only know that foam in hoses causes big decrease in vac performance ..as you found out too
