tcdepot
Does anyone have a truck mount in one of the new Ford Transit 250's? I'd be interested in seeing how you have it laid out.
Thanks.
Thanks.
I looked at the new Ford Transit. Not impressed. Your layout will depend on your machine, where you like your hoses to come out and whether your a fresh water tank guy or not.
not impressed compared to what?
To defend the pro master 3500, even Though i did not go with it
They do have 5-100k warranty on power train
And that low floor is awesome.
And my research did t turn up any major defects
Dodge Pro Master and not a fat chance in hell I would do a front wheel drive and a 1 ton rated at 9350 GVW
Seems like there is not too much space to bolt to and quite a few things you have to make sure you look out for.
So Dan, do you feel the constant weight of a tm would end up causing front end issues? That's what I would figure.
My common sense tells me a side mount tranny twisting with a heavy load from the front wheels is not the best of design and will wear faster than RWD. I also feel handling is compromised with FWD, We've all drove a front wheel car and felt the pull when accelerating. I don't see that as a good thing with a heavy load.
The transit also can come with dual rear wheels
The van is awesome. Fyi and yes it looks like a focus interior, which is great btw. Drives better and 25k less than a sprinter
Good luck with a 3.5 without ecoboost.. Really? I think my mini van has a 3.6, I wouldn't put a truckmount in there!!I priced a medium roof 250 without ecoboost for 33,000 with decent options
