Shawn Forsythe
- Joined
- Oct 7, 2006
- Messages
- 5,856
- Name
- Shawn Forsythe
Free? Heck no. I say it costs plenty!
truckmount girl said:That small leak at the wand that Shawn described is why there is supposed to be a very slight gap on the ends of most glides. It actually aids extraction.
As Shawn said, relief valves are there to keep you from losing engine RPM and power through the motor bogging excessively and/or to keep the waste tank from imploding.
Free Flow is a crude version of vac relief at best. It is "tuned" and then cannot be adjusted for changes in the system which may increase or decrease lift and thus bog or over-relieve the system. Both of which cases will hurt performance.
Take care,
Lisa
truckmount girl said:With an underpowered motor....
bob vawter said:[what if neither is applicable?
FCC said:velocity of the water moving through the hoses seemed to increase ...
Shawn Forsythe said:[quote="truckmount girl":2dq58p5i]With an underpowered motor....
FCC said:I'm not a free flow advocate by any means but....
I was adjusting my shitty spring reliefs today on a job. The hoses from my filter boxes to the waste tanks are translucent. When I depressed the relief the velocity of the water moving through the hoses seemed to increase considerably. Why?
WM pro 2000
Walrus said:I was under the assumption that high CFM's do the actual drying of the carpet.
The theory of high lift only pertains to extracting massive amounts of water as in water damage situations.
By drilling a hole into the sides , just above the slot on my POS Castex wand I've eliminated lock down and increased air movement to keep things flowing smoothly.
truckmount girl said:Bawb....unless you have leaks you aren't aware of.
truckmount girl said:FCC said:I'm not a free flow advocate by any means but....
WM pro 2000
By actuating your spring relief valve, you allowed your machine a nice, big gulp of cfm and moved all the water that was accumulated in your hoses through very efficiently..
Capt'n Marvel said:the belts were slipping a LOT and when he decreased HG, the blower started spinning faster and increased CFM
Shawn Forsythe said:[quote="Capt'n Marvel":2wvctqep]
