fresh water tank for Boxxer 427
curt johnson
Curt Johnson
what is a good option for adding a fresh water tank with a Boxxer 427 in a van? I dont want to spend a fortune and want to save as much space as possible...any ideas?
curt johnson
Curt Johnson
I dont want this van to look like Dirks....trying to be somewhat professional...
Hydro well that fits over the wheel well and has space for storage as well.
[h=3]Hydro-Well[/h][h=4]100 Gallon Fresh Water Tank[/h]The Hydro-Well is the most affordable, feature-laden water tank on the market. This tank will last the life of your truck and then some! In addition, the Hydro-Well will ensure you've got enough water to work all day without taking up your entire van. The Hydro-Well fits snugly against the side of your van and leaves plenty of room for your equipment.
[h=5]Features & Benefits:[/h]Heavy-duty rotomolded body for years of use
Transparent tank allows monitoring of water level
100+ gallon capacity
2 molded-in locations for pump sprayers
Molded-in locations for two 5 gallon buckets
Molded-in area for five 1 gallon jugs
Molded-in location for AX148B Hydro-Shelf permits storage of an additional eight 1 gallon jugs
Front and rear tie-downs for improved stability
Molded-in threaded inserts for easy pump attachment
Molded in baffles to reduce water movement when driving
Water outlets located in the back to preserve space and prevent them from being broken off by equipment
Molded in nutserts on both sides for mounting the AP36 or AP38 water pumps
Design allows the Hydro-Well to fit closer to the side wall of the van than previous Hydro-Well
Dimensions: 20" D x 36" H x 61" W
L
Lance Golden
Curt,
Call me... I have a few idea's for ya... also the one from Carpet cleaner direct...is a good one. That is a Pumptec freshwater tank
Buck1955
595 is a good price for that tank. Saw it at Advantage for 995.
My first tank was a 50 gallon shipping container. I got it for 20 dollars. There are plenty around cheap,just check out Craig's list locally. Car washes get their soaps in 50 gal. containers and go through a lot. You might get one for free.
gene
