- Joined
- Nov 25, 2006
- Messages
- 8,726
- Name
- Ron Werner
That is some sweet surgery Dr Jones.
Vince,vincent said:Leslie Judson Jones said:Daniel,danielc said:Geez what a mess!
If you lower rpm, won't that reduce vac?
This is a great question. You would think reducing the blower rpm would reduce the cfm at the wand, but it will not. Basically the reducing of the cfm is only going to reduce the amount of cfm being relieved through the relief valve, not the wands. The Roots 59 will produce 850 cfm.
Big blowers like this that are used on truckmounts are not being used for the cfm. They are being used to load the engine to produce heat. I would say when I am finished with my reengineering that this unit will have something like 650 cfm which is still more air than two wands can use while being used to clean carpets.
I am able to reduce the engine rpm because the engine is no longer used for heating. Check out my video of my test run of the unit today.
Les
would this be true for my machine since it has a 5.8 blower? Meaning do I have to run it wide open.
Lee Stockwell said:
Dan,Leslie Judson Jones said:dgardner said:[quote="Leslie Judson Jones":epxmwjzk]One severe issue with this unit was that the pressure pump was unable to move forward or backwards to tighten the belts. As you can see in the photo, on the right side of the pump the chrome shaft cover is touching the vacuum inlet pipe to the blower, preventing the pump from moving forward.
Also notice the pulley of the pump is almost touching the machine frame, preventing the pump from being moved backwards. Dan would just have to keep buying new belts when they got loose, because there was no way to tighten them.
Since the belt goes straight down, I would think moving the pump forward or back would do little to change the tension anyway. Shimming the pump up, or better yet, putting a hinge at one end and an adjusting screw at the other to raise/lower the pulley end would be the way to go.
The whole machine is a poorly thought out design for sure.
Blunt said:Is it going to have a throttle control? 2000 rpm is fine in single mode,but I would want it bumped up in dual.I run a system with an unrestricted 59,so not just throwing theories at you.
a]http://www.youtube.com/watch?v=eJmaaX_7uhga]Padden McFadden said:if only we could get Less to do that to our government.
2200 rpm's max, going from 400 cfm to 200 cfm in the vac relief valve.Blunt said:Is it going to have a throttle control? 2000 rpm is fine in single mode,but I would want it bumped up in dual.I run a system with an unrestricted 59,so not just throwing theories at you.
ACE said:Nice job Les.
That machine has lots of life left with a water cooled diesel engine and now with no proprietary parts.
A couple of questions come to mind:
1. Why LP? He is all set up for diesel. Why not add a generator and rock a diesel heater?
2. The downfall of EH units is failures in their ability to regulate heat. Why not build a boiler type HE that regulates heat mechanically rather than electronically?
Dick Jones said:Many people have seen Les's Truckmount Museum in his showroom, but very few have seen the view outside the Re-engineering Departments back door!
Just to give you guys a update on this conversion. I was planning on having it completed this week. But I'm having to make an unexpected trip to Florida. My dad's cancer had returned and he is having emergency surgery on Wed. So the conversion will have to be delayed. I will post some recent photo's of the unit. We have the propane heater installed in the van and the propane tank mounted.woodsey said:So when do we get to hear about the end result in the field??
Leslie Judson Jones said:ACE said:Nice job Les.
Mike,
I’m sorry I missed this post and did not reply sooner. The reason I don’t like using diesel-fired water heaters is that diesel-fired systems are fairly inefficient as far as cost effectiveness goes. Also, diesel-fired systems have a lot of electrical and mechanical parts to make them operate. They have a flow switch that activates a pump system that atomizes the diesel fuel and a magneto to fire it with an electric spark. Every time you pull the trigger these systems activate. Really a diesel system is made for pressure washing. When pressure washing you’re not cycling the trigger so often. You basically pull the trigger and hold it on for an extended period of time like when you’re pressure washing the side of a house. Another draw back with diesel is that it stinks. The reason I like LP is that it is a simple mechanical control that is reliable. It is extremely efficient with copper coils and clean An LP system with 180,000 BTUs with copper coils would be the equivalent of a diesel-fired system with steel coils at 250,000 BTUs.
To reply to your second question concerning heat exchangers; there are not enough BTUs in the system to maintain 240 degrees on a high flow wand under commercial carpet cleaning conditions. The closest thing to the most trouble-free heat exchanger that has ever been built is the one we built for Cu, the Reactor. This system is very unique because the only control on it is a car thermostat, which is mechanical. The thermostat just simply opens and allows the water to run through a radiator which removes excess heat to stabilize the system. However, this system will not maintain 240 on a high flow wand. But it will maintain 210 on a standard flow wand.
v]http://www.youtube.com/watch?v=wnFSVoXMMRMv]woodsey said:So when do we get to hear about the end result in the field??
Leslie Judson Jones said:e]http://www.youtube.com/watch?v=wnFSVoXMMRMe]woodsey said:So when do we get to hear about the end result in the field??
