My genesis' water pressure suck. I have replaced the pressure regulator from power clean that doesn't have the check valve I double checked it. I replaced the qd's on the front pannel. No matter what pressure I dial it up to it drop at the end of the hose to about the same pressure. Whether it is set at 500 or 2000 psi it doesn't matter it drops down to the same pressure at the end of the hose. The gauge doesn't drop at all what ever I set it at it stays at the pressure set at the gauge.
Any ideas??? I haven't seen any screens or anything any were obviouse that could be clogged up. I have been dealing with this since I bought it last month.
