got a new engine for $27
I know a lot of you guys are great mechanics, so this post may seem really lame to you, but I only know enough to be dangerous at times.
My 25hp Kohler was sounding really rough, almost dying under load, wouldn't even pull 15"Hg anymore.
Changed the plugs for $10
Still running rough.
Turned out to be the airfilter! Could still see light through it but the thing was plugged!!
That Kohler sounds like a new engine now! Sounds really strong and solid at full revs and it barely slows down under load.
Now, every 500hrs, new plugs and filter
Check your airfilters.
not that dusty here.
I was dumb, I know, ran that last filter for 3 yrs. didn't look that bad.
Surprising thing is how well this unit ran all this time not operating at 100%
yep...been there done that .
Found out by accident really
It was many years ago ...we were slammed in the heat of student rentals .
a two to three week period that a bazzilion empty rentals have to cleaned ..ON TIME
TM is running two shifts and porty going full bore as well
the TM starts to sputter and die under load...."FCK!!! this is all i need now", I thought
so I pulled the air cleaner to have a peek at the carb.....and BAM!! she runs like a top :shock:
..l.T.A.
Johnny
Johnny
A few weeks ago, my 25hp water-cooled Kohler started smokin bad and continued to run when I cut the ignition. Turned out to be the fuel pump mounted on top of one of the valve covers leaking gas into the valves on one cylinder. Replaced the fuel pump. (After I replaced a good $150 fuel shut-off silenoid.)
KevinD
Kevin Dumas
Thanks for the reminder. My 38hp Kohler was stumbling a bit on Friday.
I ordered in both the inner and outer filter about a year ago but never put it in... cause it always looks good in there.
Maybe new filters and a set of plugs might help.
rwcarpet
Robert Hodge
Ron, Thanks! I went out and checked my airfilter today, and it was filthy! I had installed an aftermarket super-duper high flow air filter a few years ago and just...forgot it. Popped another one on 2day, and what a difference. Tomorrow will prove the difference.
rwcarpet
Robert Hodge
Oh...and it was about $25 bucks.
