Grease Eater and Atomic X Series now also in 30lb Pail!
deedeebaig
Buy Grease Eater X Series
And Atomic X Series in a
30lb Pail and Save!
In 2008, we discovered a surfactant that was organic but 12 times more powerful than what was available on the market. This led us to move from phosphates (that have environmental issues) to using this new surfactant to make Grease Eater even stronger. The surfactant content and the content of other contents (like Citrus, Oxygen, Enzymes) are double of what they are in our regular Grease Eater. The reduction in the size of the surfactant also decreases the freight cost and Grease Eater's environmental footprint. And our X-Series was created!
Here are some key benefits of Grease Eater:
  • 1 oz will make a ready to use (rtu) gallon.
  • pH of 10 neutralizes the pH faster.
  • Surfactants loosens up the dirt quickly.
  • Citrus (delimonene) dissolves oil based stains like grease and oil. Helps break the oily bond associated with Polyester, Olefin (see a Video), Triexta and Nylon.
  • Oxygen (hydrogen peroxide) makes organic stains like coffee and urine just disappear.
  • Organic salt conducts the heat evenly throughout the Grease Eater and your solution for even and stronger cleaning.
  • Enzymes (natural) are grown specifically for Grease Eater. These enzymes are not "lab made" like competitors. These enzymes, that can also be called beneficial bacteria, dissolve protein based stains and odors.
  • Great fragrance (not just a scent but a perfume) makes it pleasant for you and your customer.
  • Crystallizers help you and your customer keep the carpet cleaner than water or using other popular chemicals.
  • Specifically designed by our founder for his own carpet cleaning business to help him reduce labor costs.
  • No chemical works better on "trashed out" restaurants and apartments.
Buy 30lb Pail Now
This is a true crystallizer that surrounds the left behind dirt.
  • Dries 100% brittle, with no sticky residue, to keep the carpet cleaner longer!
  • Pleasant orange smell.
  • Made from safe and natural ingredients.
  • Add 1/2 oz to 1 gal. water, stir until dissolved.
Consumer Alert: Our competitors products contain optical brighteners that make the carpet look shiny and white, but as the carpet dries and the days that follow, the carpet gets “duller”. Plus, optical brighteners are not environmentally safe and not approved for carpet use by many institutions, including the IICRC
With Atomic Carpets get even cleaner the next day! Now that is a unique technological breakthrough! No other encapsulator can say that!
Buy 30lb Pail Now
You can also call me (Dee Dee) if you have some questions! 877-926-3748 ;-)
Goomer
Bronx, New York
Frank Mendo
By far, the worst grammar in the industry.
I can't imagine it helps their sales.
They should have everything proof-read and corrected by someone familiar with Engrish.
