Grease Eraser
Jamesh921
Central Oklahoma
James
from Chemeister's Official website (greaseeraser.com)
Solution Line Type Sprayers - a perfect companion
Just Mix Six Scoops of Grease Eraser in your 5 quart reservoir.[/
and from Jon-don's website;
•In PowerForce sprayers: mix 6 measures (18 oz) to the 5-quart reservoir and mix with hot water.
That's a big swing in dilution ratios.
Anybody know the correct ratio mix??
Looks like they are both saying the same thing. 6 scoops, the other 6 measures, both = the same amount, 18 OZ.
Now if it were power max, it would say 8 oz per gallon on the container, then on this board you will be told the real dilution , of 2-4 oz per gall. The 8 oz per gallon is for those prfessional s out there using a rug doctor. Or a small porty,
Jamesh921
Central Oklahoma
James
Well, all the scoops I've recieved in pails of chemical were 2 oz scoops (with the exception of S & G which came with a 1 oz scoop).
So, are Chemiester scoops 3 oz??
joey895
Florida
Joey J.
Re: Re: Grease Eraser
Yes,
Sent from my ADR6300 using Tapatalk
PCCN
Chemeister ships with a 3 oz. scoop for Grease Eraser. I use it religiously. Over the years I have found 8 - 3 oz. scoops to my 2 gallon, in-line sprayer is perfect. I use this on residential and commercial. Even a bit lower if I know I'm not going to be doing heavily soiled carpet.
Slop has a 1/2 oz scoop
joeynbgky
Bowling Green
Joey
Grease eater is 2. Oz a gallon but comes with an 8 and a 2 ounze scoop
Sent from my T-Mobile G2 using Tapatalk
Ne
Do you guys count sections of toilet paper and measure out your toothpaste too?
Art Kelley
Clawson,mi
The most concentrated I have ever mixed Grease Eraser is four scoops (12 oz) in a five qt container for a 9-1 HF, and that would be a very rare occurrence, an absolutely trashed shithole. Usually it's either 2 or 3 scoops for most jobs. I've never used 6 scoops. You want to rinse out everything you put down, and this lower concentration is easily removed with fresh water rinse.
