eziway
After cleaning for many years without a glide, I installed a slotted green glide on a prochem quad. I have a problem with a high pitched whistle when the wand is lifted off the carpet or when you lay the wand down to move something. I have sealed around the edges with goop and it did not help. Any suggestions .....I like the how easy to push the wand with the glide on but the whistle is very loud . Would a hybrid or holed glide be less noisy ? Any help would be appreciated......If you cover the middle slot the whistle sound is greatly reduced or if you idle the truckmount down to reduce the vacuum.
