here is their website for "green chems"
http://www.hcronline.com/greencare.htm
maybe it is a product similair to this one:
Green Carpet Prespray GP-160
SECTION l
HARVARD CHEMICAL RESEARCH
3595 ZIP INDUSTRIAL BLVD.
ATLANTA, GA. 30354
Date 10/19/08
Phone:
INQUIRY- (404)-761-0657
EMERGENCY- (800)-424-9300
SECTION ll HAZARDOUS INGREDIENTS/INFORMATION
HAZARDOUS COMPONENTS CAS# OSHA / PEL ACGIH / TLV OTHER / STEL %
Glycol Ether DPM 34590-94-8 100 ppm 100 pmm
SECTION lll -PHYSICAL/CHEMICAL CHARACTERISTICS
Boiling Point: >212 F Appearance and odor: Clear liquid with low odor
Vapor Pressure (mm Hg): N/A Specific Gravity (H20=1): 1.04
Vapor Density (Air=1): >1 Melting Point: NA
Solubility in Water: Complete Evaporation Rate
Butyl Acetate=1) N<1
SECTION IV-FIRE AND EXPLOSION HAZARD DATA
Flash Point (Method Used):NONE Flammable Limits:LEL: N/A UEL: N/A
Extinguishing Media: Water fog and carbon dioxide and dry chemical
Special Fire Fighting Procedures: Do not enter confined fire space with out proper protective equipment including a NIOSH approved self
contained breathing apparatus. Product does not burn but can provide oxygen which can intensify a fire, toxic fumes may be released.
Explosion Hazards: NONE
SECTION V-REACTIVITY DATA
Stability: Stable when stored in proper container under proper conditions.
Incompatibility (Materials to Avoid): atmospheric metals strong reducing agents including hydrazine, sulfides, sulfites, copper, zinc,hydrogen
and hydrocarbons.
Hazardous Decomposition or Byproducts: Heat, carbon dioxide, and carbon monoxide.
Hazardous Polymerization: Will not occur.
SECTION VI-HEALTH HAZARD DATA
Health Hazards (Acute and Chronic): NONE KNOWN
Routes of Entry, Signs of Exposure, and Symptoms of Exposure:
SKIN and EYES: Severe irritant to eyes.
INHALATION: Irritation to respiratory system
INGESTION: Gastric pain and vomiting.
Medical Conditions Generally Aggravated by Exposure: Unknown
Carcinogenic: OSHA Regulated: Ingredients not listed.
Emergency and First Aid Procedures:
SKIN & EYE CONTACT: Rinse skin with clear water. For eye contact immediately flush with clear running water for 15 minutes. Get
medical attention.
INHALATION: Remove to fresh air. If breathing does not return to normal, get medical attention.
INGESTION: Immediately drink large quantities of water. Get medical attention.
SECTION VII-PRECAUTIONS FOR SAFE HANDLING AND USE
SPILLS: Dispose in accordance with federal and state regulations.
Handling and Storing: Keep container closed when not in use. Away from excessive heat and don’t mix with anything.
SECTION VIII-CONTROL MEASURES
Respiratory Protection (Specify Type):Yes.
Ventilation: Mechanical: Recommended.
Protective Gloves: Rubber or neoprene.
Eye Protection: Safety glasses.
Other Protective Clothing or Equipment :None.
SECTION IX-ADDITIONAL INFORMATION
