Grey grout turns white
Walt
Cleaned some slate today. It wasn't very dirty so I just used a cleaner from coastwide labs. Mopped on scrubbed by hand. Rinsed with wand. It was to uneven for rotary.
As it dried, all the grout turned a much lighter color of grey. Except the bath room, which has same tile and grout.
What gives? How do I fix?
danbrown
It was too uneven for a rotary (im assuming you mean a turbo or the like), yet even enough for a wand? Now that doesn't make any sense at all...
Was this coastwide labs cleaner a degreaser or what? What was your dilution rate?
Perhaps the bathroom grout is still dirty.
Moar pics....
alazo1
San Jose, Ca.
Albert Lazo
Efflorecense?. Hit a line of grout with acid to see how it reacts, bring a small wire brush. You didn't seal it right?.
richard
St. Louis, MO
Richard Weedman
efflorecense probably. sometimes a wire or stiff brush alone takes care of it.
getdusty
Is there a coating on the grout? Slate is often sealed with a topical sealer, or wax even. It coats the stone and the grout.
