HDPE PLASTIC WELDING WATER BOX
Bjorn
making a water box for a customer with an outdated truck mount exact copy of the current leaky one out of hdpe plastic
yes that is Frank Christmas music just needed for a cold week end pre holiday
q]http://www.youtube.com/watch?v=BlRZqLQHdFsq]
q]http://www.youtube.com/watch?v=lb-GD2JoR54q]
q]http://www.youtube.com/watch?v=qhb-9cX53Gcq]
looks easy....but lets get a close up of that bead...
i'll match ya.......
No T i'm serious...
i would LOVE to see a close-up of that bead...
does it look like a tig weld......
show us yor nervous tic........
can you drill and glue in bungs wit NIP threads...........?
Bjorn
you cant thread this product do just about anything with it as you can with metal even with heat bend it.
still takes the same time to prep and weld this stuff as anything else
you can only weld the exact same material like hdpe can not be welded to Uhmw or Delrin
Bjorn
they might have them some where as long as it's the same material it can be plastic welded
so HTH do you put a ballcock or a level control in........
Bjorn
why does every thing have to turn into a pissing match it's just a water box
u]http://www.youtube.com/watch?v=3vNXb5sY6_cu]
g]http://www.youtube.com/watch?v=3vNXb5sY6_cg]
no pissing match Terry......it was a legitimate question...
i see NO ability to control water input....
is there a ballcock float of some kind to keep the water from overflowing....
touchy...touchy?
John Watson
Great lookin there T, What type of penatration do you get with that elec torch??? Is that 3/8, 7/16 or 1/2 Lp???
Looks like no tic needed jess liik SS stick and Jet rod let her flow baby if you gots her dialed in to yer machine right or was that left??
Bawb, Hees gonna hooks it up the same as they duz on ther Toilet them called thru hull fittings.. wid gaskets...
Bjorn
YES BOB THERE IS A FLOAT it's just not in yet it will have the same plumping as the old water box
you must be on some good drugs
no go have a double cheese burger
thanks John least yur on the ball
Captain Morgan
Bill Morgan
sweet, no slag !! how long do the plastic welds need to cool or cure before you can use/put pressure on the seams, like if you were going to drill holes for handles, latches or other plumbing? is it a difficult technique? Do you just drag it through the edges of plastic or do you weave it? Sorry the picture of the bead didn't show up clearly on my computer.
Thanks T.
Bill
JHC...
I jus ASKED how you were gonna attach the ballcock.
a civil answer would suffice.......
t...yor thong must be a little tight.........................
number one: i was curious
number two: i could give a dED rats patudi 'bout yor little plastic box.....
so there.........
Lefty724
E
Hey I have one of those heat welders! Except I use mine to heat weld all the seams in my floors!
Is your 35 gallon waste tank made out of the same material? Same process? Water tank looks great!
La Canada Carpet Cleaning
Looks nice Terry, I like the shop with Heater. You are quite a crafty guy.. Is Frostys still open ????
Ross Buettner
Ross Buettner
Hmm.. I was thinking of looking into getting a fresh water tank made up with that material.
Are there people out there that do that?
Contact Terry and he can make you a custom waste tank of that material.
KevinD
Kevin Dumas
So Terry, Can you thread this product? or "you cant thread this product"
I see where the confusion lies and why Bob was asking.
thank you Kevin...that's exACTly what i was wondering...
it's nice to see that there is SOMEONE of sound mind left on this board.............
joe harper
joe harper
Here is a waste Tank of the SAME material...yes it can be threaded... 8)
Also you can "customize any thing you want on it.."Like the battery box on top"..
