Heat exchanger replacement or fix
Seabass003
Callahan Fl
Curtis
I have discovered i have a leak in one of my heat exchangers on my hydramaster 4.8 Overdrive. I am not sure which one is leaking I am considering doing a pressure test on them but I am not sure quite how to get the pressure high enough to test. I am also wondering if there is a aftermarket heat exchanger that would be equivalent that is cheaper than $900 being I will probably buy both. Thank you
Village Idiot
will you be creating an account for each question?
Village Idiot
I am not sure what you were talking about this is a different guy
weird....even the same IP
I don't know of any aftermarket exchangers since it looks like John's Custom is completely gone now.....but you may try the number
727-581-1700
Seabass003
Callahan Fl
Curtis
I don't think there are any aftermarket exchangers since it looks like John's Custom is completely gone now.....but you may try the number
727-581-1700
I guess my business partner must have talked with you and he was over here earlier so that's got to be it
