When did LM (low moisture) become VLM (very)?
Do any of you old timers recollect when the Very was added, and why?
I doubt I've had any influence on it at all, but in my classes and the training manual that I have used for a few decades, I had two cleaning methods described like this:
1. Low Moisture/Low pH. This method was the use of a neutral preconditioner applied by a mist or a foam, then followed by rinse extraction using a "dry tool" (Upholstery Pro, Drimaster, Etc) and an acid rinse.
2. Very Low Moisture. This method was at first dry foam cleaning with a sponge, and now the use of a neutral "encap product", followed by extraction using an orbital buffer and a cotton or microfiber towel.
I believe Joey Pickett uses similar terms as well.
I haven't liked using "encap cleaning" as a term for upholstery cleaning, as the concept of applying a product, brushing it in, then vacuuming a day later just doesn't make sense for fabric cleaning. The immediate removal of soil with an orbital buffer leaves the fabric dryer, softer, and nearly residue free.
Still, I doubt my upholstery cleaning concepts have made any impression in the thinking of the average VLMer out there.
Georgia
All I know is people walk on the carpet with shoes, very dirty shoes. Buffing it doesn't do anthing but picking up some of it and hiding the rest of it.
Get a real machine that puts out solid heat (boiling water), not tap water warmth and holds a true lift while the hoses are full of water and flush that carpet out (600-700psi).
I"m willing to bet that all the VLM'ers never had an Everest size truck mount, only Mikey370's
And those who do have Everest size truckmounts, run it on dual mode and clean with top heat. And quit being a sissy and turn up that butyl mixture (or saiger soy if you want it to sound natural, lol)
I protest buffing carpet. for all the carpet buffers...put your nose on it after it's dried from buffing and tell us how fresh it smells in the high traffic, heavy soiled areas. The nose is more accurate than the eyes
All I smell after you pad soaking dopes leave is mildew, for weeks...
