Heat
SuperiorF
Dec
Role
Cleaning Professional
Years of Experience
1
Can you use diesel heater inside of van? Not sure how I can get extension cord out of the house without going thru a window and would be the same at the van. Any ideas?
scotty747
I did for years. Still have it as my backup. When I had it in a cds I ran it off an inverter since the van was running anyway. An extension cord to the porch or in the front door is no big deal. Make sure it has a GFI though.
Hire someone to mount one of these depending on the size heater you want to use if you choose electric
Swani
I have run a Chinese diesel heater when needed. Make sure you get the kind you can exhaust outside. Mine is DC and runs off a battery. They work amazing. Not bad insurance to run windshield washer fluid through everything at night either. Cost you about $10. I would always work the cost of winterizing into my invoices by charging a few cents more per square ft. I always upfront with my customers about it and they always understood.
Are you asking about Heat for keeping your van warm during winter, or using a diesel heater to heat your solution line?
I never had to worry about winter.. I'd give up if I didn't have a heated garage.. Too much bs to winterize it..
KevinD
Kevin Dumas
They have 12 volt diesel heaters but I would recommend an additional 12 volt battery wired to charge off your van with a switch to recharge while driving.
sassyotto
Paul
Im thinking your talking about heating the van, not the solution line. You should be able to put the extension cord between the two back doors on the bottom
