Help! Machine Running Puny.
Johnny
La-Z-Boy
Johnny
PowerClean Freedom 47. Kohler 25 hp water-cooled.
Yesterday it started running puny, like missing a little. When truned off at ignition switch, engine continued to run. Had to throttle down to stop it. (This not-turning-off is intermittent. Sometimes it will.)
Good plugs, filters, etc. Don't think it's bad gas; refilled midday yesterday.
Thinking it might be a relay for the ignition problem, but would that make the engine run puny? Both symptoms started at the same time.
Distributor is closed today. Overbooked for at least a week so it would be a problem to take it to him without making customers unhappy. Doing a couple jobs today to catch up a little.
Any ideas will be greatly appreciated.
joe harper
florida
joe harper
Could be ...the ethanol...in fuel...!!!
I posted 6 months ago...You gentlemen up NORTH...should be PREPARED for this gReMlIn.. :x
Be prepared to CHANGE out your fuel pumps..Every six months ..or ..Every 300 to 500 hours.!
DON'T..forget to change out the rubber fuel lines...!!!
Do it as a "preventive maintenance"..procedure...just like changing your oil... :idea:
The ethanol ..degrades ..any rubber o-rings in the carb,fuel lines,fuel filters, "which effects"
plugs, points,...any thing that the fuel touches.... :!:
You HAVE ..fuel & fire or she would not run... :idea:
Before you start Changing PARTS....over haul the fuel system.."You may Be Surprised."
ps..if this does NOT solve the problem...Check for a bad ground..voltage regulator..loose
wires on the "back" of the ignition switch..."Over time they can vibrate loose..." :idea:
La La Land
Make sure that you don have a lawn mower engine that has worked itsef to death...
25 HP is purty much running 100% capacity...for that motor!
just a "guess" , but are your HX'ers plugged/restricted ???
can too much exhaust back pressure cause the problem?
....kind of like a clogged catalytic converter on a vehicle??
Shane T
Waukesha, WI
Shane Tiegs
How many hours on your unit. I'd first be checking things on the electrical side. Make sure all connections are tight. Start at the ignition switch.
Johnny
La-Z-Boy
Johnny
2000 hrs.
Took ignition switch out Sat. morning to find replacement, which nobody open had. I think there's a relay past the switch. I'll check that next.
It ran good enough to work yesterday. Runs better at higher rpms, and maybe when hot. But stumbled when I reduced the rpms to cool it down. And it's slow to start.
Johnny
La-Z-Boy
Johnny
Good idea, but new exhaust HX a few months ago.
