help me help me
kevinj61
I am getting ready to try encap for the first time and can't decide best way to apply chem, i will be using a 175, should i use the solution on the 175 to put down the chem, or spray it on, should i use the carpet brush or pad driver with fiber plus pads, these are the options i have, i of course want to do which ever gives the best results. So what do all you seasoned veterans think
Kev, if you're talking full blown "scrub 'n run" sCampooing and have a shampoo tank on your rotary, shower feed the encRap juice with fiber pad
the other method is to bonnet clean .
Then you'll spray the pixie dust juice
Royal Man
Lincoln NE
Dave Yoakum
When ever I use a pad and a showerfeed it just throws the juice all over. :(
I have a tech with a backpack spray the juice drictly ahead of the 175 with a bonnett for the best results.
You should get a slight whitening of the juice as you run over it.
Brian R
Little Elm, TX
Brian Robison
I like spraying it with my cool sprayer set up.
If I practiced the onboard sprayer type thing I might like it better.
