help me fully understand this encap process
Apparently encaping is only suppose to be a maintenance type cleaning and should still be cleaned using HWE method after 2 to 4 times of encaping it. This I assume is because almost everyone says that encapng is not a real deep down clean as HWE is and your not really pulling anything out of the carpet, so correct me if i'm wrong or if you disagree, the encap process is 1. you put down whatever encap chem your using ( this is down in the same manner you would put down normal pre spary as if you were going to HWE) 2. you then use some sort of powered/mechanical agitation like a cimex, or 175 or whatever you use, (this works the encap chem into the carpet the same as it would work a normal pre spray into the carpet for HWE) So at this point encap or HWE the process is the same except of course the chems. Now this is where the big difference comes in, if your using HWE method you would then use your extractor to rinse and extract the prespray and all the dirt along with it. Whereas with encap your done after your agatation ( leaving everything still in the carpet ) But wait there's more, isn't the encap chem suppose to, when it dries to tiny crystals entrap all the dirt and stuff so that when you vacum you are in reality taking the dirt out of the carpet, your just doing it when its dry as opposed to when its wet. And the better the dry vac you have obviousley the more you'll get out, much the same for HWE, the better the suction of your HWE machine the more you'll get out. Now far as i know most guys use the encap for commercial only (not that you couldn't do it in residential, depending on the type of carpet cust has) but encap is mostly used for commercial. Way less chance of wick back or stains coming back--I have went in and did HWE on commercial jobs after it has been done with encap prior and looks great when your done but then the next day they call you back and say "Hey where did all these stains and spots come from) i'm sure this has happened to alot of us-so why not just encap commercial jobs always and leave it at that
