Help needed
I'd recommend using stout angle brackets. Drill a hole all the way through the van rib and use a bolt and nylock nut to secure the angle to the truck. Then put a bolt and nut through the shelving. Screws can pull out.
John Olson
John Olson
No they don't come with brackets you need to drill through the floor and used hardened bolts and washers on all four legs and you can then use self tapers in the middle of the top two shelves to hold the shelf from swaying.
