joeynbgky
Cat 290 losing pressure what could it be? I checked everything
Sent from my g2 using tapatalk. Whofat
true...but i wonder how many pumps will pull directly from the FWT on the OTHER side of the truck.......cuz a LOTTA people use those little sure-flo or jet-pro or what ever they call them......Lee Stockwell said:A Wanner will likewise loose pressure if sucking air.
true...but i wonder how many pumps will pull directly from the FWT on the OTHER side of the truck.......cuz a LOTTA people use those little sure-flo or jet-pro or what ever they call them......[/quote:110bw7ak]bob vawter said:[quote="Lee Stockwell":110bw7ak]A Wanner will likewise loose pressure if sucking air.
joeynbgky said:I still think the pump has an issue. With the psi dropping so much.
true...but i wonder how many pumps will pull directly from the FWT on the OTHER side of the truck.......cuz a LOTTA people use those little sure-flo or jet-pro or what ever they call them......[/quote:2q7pvcue]bob vawter said:[quote="Lee Stockwell":2q7pvcue]A Wanner will likewise loose pressure if sucking air.
