rwcarpet
I had the Genesis out today to help out for the United Way "Day Of Caring", which of course was a free-bee. I was helping out in a downtown area with gum on the sidewalks. With the genesis up to full heat, I was peeling gum up with the pressure gun at about 1500 psi. I wanted a little more pressure, so I cranked it up to 1800 and cleaned for about 5 minutes before I heard a pop and lost pressure. Sure enough, the high pressure relief valve popped. So I wrapped it up and headed back to the garage to change out the valve with an extra I had. This relief valve is mounted on the heat exchanger chamber, and is factory set to pop off at 2800-3000 psi. After changing it out, I tested it and it,too popped off. Now I took the original apart, and cleaned it, and reinstalled the original valve........tested it and it popped, blew the whole top off the valve. (probably due to it being brass and 8 years of heat and pressure). The whole time, the pressure guage never went above 1800 psi. Wouldn't the safety valve protect the whole pressure system? Am I overlooking something? Could it be maybe some scale had broke off and jammed the unloader bypass system? Since there are no PowerClean techs to talk to, I need the experienced TM builders and experts here to give me some ideas of what to check. I was trying to track down jim Nape today, but couldn't get to him. Powerclean dealers.......HELP!
