Help with RX-20 Mods
Shane T
Waukesha, WI
Shane Tiegs
I know its been talked about before, can someone help direct me to the thread about lowering the jets. I'm running GG and need to make the necessary adjustments. It is the old style star.
Arizona
you can lower the jets with the extension check valves....
pending how low you want to go..and your jets..there are 2 different lengths.....
these are the long ones......
Arizona
I ran 80015 with the shorter extensions before it finally blew up on me...ran that configuration for about 2 years...seemed to be the best set up for me....
I used different elbow so a few of the jets would hit more towards the inner part of the vacuum and the others would hit towards the outer portion of the vacuum. I could not get them line up dead center. Also I like the glides because they pop on and off really easy so you can run with or without depending on the job. I run 80015 jets.
