Jun 4, 2009 #1 R Ron Lippold Guest I think I have a bad diaphram in my chem pump Please help I could use a break down if one is avaliable. thanks
Jun 4, 2009 #2 Mikey P Administrator Joined Oct 6, 2006 Messages 117,239 rip that pos off and call Les.
Jun 4, 2009 #3 SMRBAP Supportive Member Joined Mar 29, 2009 Messages 667 Name Anthony what chem pump - and are you looking for a schematic?
Jun 4, 2009 #4 C Chris Sheldon Guest Ron, I see you are in ABQ. A&R Supply has those diaphragms in stock.
Jun 4, 2009 #6 A ACE Guest I’m not what sure about the V’s but, most chemical pumps don’t do well at high PSI. I put a high quality ball valve in front of the chemical pump so I can turn it off when I do T & G. Before that I was doing lots of rebuilds.
Jun 4, 2009 #7 Jim Martin Supportive Member Joined Oct 7, 2006 Messages 10,877 Name Jim Martin did you look at the check valves..........
