Bjorn
- Joined
- Oct 7, 2006
- Messages
- 2,450
r]http://www.youtube.com/watch?v=fldCgcXTsFQr]
Rightie Tightie said:Dave Retire????????????????????????????????
Well ... what is it?DevilThomas said:Looks great!
How about the specs?
temp, psi, vac lift, cfm???
What do you plug it into? Total amps used?
Price....?
tmdry said:T,
Bom trabalho...gostei!
juniorc82 said:too bad the little giant is the muscle behind the heat. a propane heater kinda defeats the purp. of an electric mount
Erik said:IMO, it looks like the unit needs more vacuum, everything else looks awsome...round waste tank, 3 ht, 120,000 btu, plenty of heat for an 8 flow at 450 psi. I would ad one more 3 stage vac mounted on the right side of the machine on the outside of the panel straight into the exhaust of the motor. Use it as a booster. If you can't find a different circuit, which you probably can in a commercial building, buy a small generator....probably $100 on sale for the situations you may need a little extra vac. I only say this from experience. Years ago, I had 4 3-stage vacs hooked up to a square box, 3' x 3', high pro, 500 psi pump. One plug ran the pump and one vac motor, one vac motor ran off of another plug and the other two ran off a generator. The unit was good, up to 150'. I grabbed the wand on a rainy day that was resting on the vacuum motor after hooking it up and I got lit up like a fu***** christmas tree.
DevilThomas said:Was talking to old Dave at Swan's
