- Joined
- Oct 6, 2006
- Messages
- 117,373
Can a cleaning solution really be used as both a pre spray and a rinse effectively and not create either a resoiling issue or be hard on your machine?
Something like this has me wondering..
Clean Streak PLUS!©(6.5 lb.)
Description Directions
Powdered, enzyme- based carpet cleaning detergent and restaurant prespray. Contains surfactants and a blend of degreasers. This is as good as it gets for restaurant presprays...
Clean Streak MSDS (PDF) MIX: Use hot water . 1 cup (1/2 lb.) to a 5 gal. chemical reservoir and meter at 3 - 5 G.P.H. For prespray add 1 cup to Hydroforce container (9:1 ratio) or add 1/4 cup to 1 gal. pump sprayer.
Not for stain resist carpets: pH 12.5
1 @ $27 4 @ $94
