c_adkins said:
I am curious, after hearing about the volume you do daily, I was hoping you might share some time-saving tips. I.E. what tools do you bring in when, set-up and tear down, etc. How much time do you spend on pre and post inspection and dealing with custys face to face? As a solo operator I am impressed by how many jobs you manage to get done in a day.
start to finish..........
When ever I walk up to the house to ring the door bell I always have my vacuum cleaner with me and my bag
In the bag I have some spotters....tabs (both types) rags ...sliders...lift buddy...all the little things that keep me from running back and forth out to the truck.. I set these by the front door and ring the bell...
Once in.... I have the client give me the lay out...what they want moved.. any problems that may may have......etc....BS with them a little pet the dog (if they have one ) and get to work.....
Set clip board by front door and grab vac and bag....sliders and sticky tab what ever I can....Pre-vac all areas..I never ever pre spot unless it is something like a plant stain or things like that...asnd that is normally just a quick spray with a bottle....
Take vacuum back out to truck...( I have already save a bunch of trips)....Grab Mytee sprayer and rake...take inside... throw down mats in door ways spray the first 2 rooms and agitate........
While those a fermenting On my way out I move the sprayer out of my way to the next set of rooms...
Go out to the truck and take of my first 20 foot of hose and my wand ( I always carry in the first 20...It goes faster to lay it out at the farthest point and work back then to try to drag it all in at once)....
Then I will wrap the next 50 foot on my arm just before the cuff and bring it up to the door and lay it out hook it to the 20 foot piece I already brought in...Hook up my "Y" and my filters and a 4 to the door hook up...
( I have my hoses set up in the truck for a long run or a shot run ..which ever I need....)
From there I finally fire up my truck set my pressures and bring in my solution line....
Hook everything thing up and clean the first 2...After they are done I move the hoses to a neutral place....spray the next set of rooms and agitate..while they ferment ...go back to the first 2 and groom the areas...move my mats turn on all ceiling fans (if they have them) and go clean the next 2...and so on...
when I get to the last areas...I spray it down and by then I can take the bag and the sprayer back out to the truck while those areas are setting...Clean the final areas and the only thing I have to take back out to the truck is my rake and my wand.....roll up hoses....change nylon in filters and have it ready for the next job
collect my check...kiss the client ..pat the dog one more time and head to the next one........
