Vinnie
Now that you sold your V, what are you using now or what kind of Mach. will you get.
fred boyle said:It comes with a 4HT Heater ,dumbass... you didn't upgrade it
http://tcsatl.com/chief2.html
TCS CHIEF II
Standard Features
27 HP Kohler
Sutorbilt 4L @495 cfm
Cat 290 @ 1200 psi
Little Giant 4HT @ 180,000 btu's
300' vacuum hose and reel
300' solution hose and live reel
150' water supply and live reel
55 gallon fresh water
175 gallon recovery
The Chief II is the flagship of the TCS line. Powered by the legendary Kohler 27, the high-performance 4LP (#47) blower provides all the flow you need for dual-wand performance. The additional air flow and waste capacity make the Chief II an ideal choice for the serious restoration professional. Cleaning in dual-wand configuration helps cut the amount of time it takes on large cleaning jobs in half. Another feature is the 180,000 btu propane heater that provides sizzle, even with both wands working at the same time. The Chief II will be the last truckmount you ever have to buy. No other machine at this price can match the performance and dependability of the Chief II!
Total Cost: $18,475.00
Bob Savage said:Lyman, I believe what Marty said.
The design itself of a vacuum system can completely change (markedly improve) the vacuum ability of a given vacuum source - i.e., a 33 blower in the right vacuum system design will kick ***.
joeynbgky said:
cu said:bout time you came back to the real world.now be happy , make some money, stop reading ics posts about uping your price's and shut the fook up
shhhhheehh pissy are't we!If I ever get around to actually taking a picture of it, I probably will only send it to Joey.
The rest of you disrespectful dimwitts can just kma.
Especially YOU, Cameron.
Doc Holliday said:shhhhheehh pissy are't we!If I ever get around to actually taking a picture of it, I probably will only send it to Joey.
