HF temperature restriction?
Bucey
Whoville
FFA?
Is there a temp restriction on the function of the HF. Does it stop working at higher temps?
Benton KY USA
Theoretically yes. If it is a problem LOWER your pressure, and perhaps throw in an extra section of solution hose as a "radiator" to lower the temperature a bit.
Benton KY USA
The venturi effect is measurably less in two situations:
1. As the pressure increases the percentage of chemical draw decreases.
2. As the temperature at the dema valve rises above about 180 deg F. the percentage of chemical draw decreases.
I listed first, turning the machine temp down to address #1. Adding a length of hose will reduce the temperature and pressure, thus addressing both limits.
Thanks,
Lee
