ronald pantelas
Please answer this for me? Today when doing a restaurant with my greenhorn. I had the psi at 750. At that psi , I filled my 210 butler waste tank within 3.5 hours. Grennie can you tell me at what psi its overkill. I dumped out, started back to work, this time I turned the psi down to 650. I saw no noticeable difference in the cleaning results. It looked like I could of cleaned at even higher psi if I wanted too. With the 2.5 hose and the hybrid glide is there no ceiling on where you set the psi levels on commercial carpets. No issue with dry times, I'm just curious what you think. I think after 650 psi with 15 flow, it might be overkill. Ron
