high heat solution hose
adamh
Does anybody know of any really high heat solution hose? There are many that are OK at 250 degrees but is there any that are OK for 290-300?
What are the guys running with Propane burners? They get way more than 250 degrees.
Thanks
Adam;
We have a wire-braid that is cover-rated @ 275°. Manufacturers spec is 300° F.
Mikey Board Supporting Member
Most HIGHER heat hose is rubber core and steel braided.
If you are serious about the heat, choose a teflon core, Stainless Steel braid,and polyurathane jacket, just don't put it in a loop and kink it.
Only stuff I have heard about is Kodiak hose. I forget where I saw it. Rated around 275 I think.
One way to do work around it, use teflon-lined stainless braided hose for the first 15-20 feet. BY then it cools to the limits of the other hose.
