higher flow for boxxer 421
Joel D
Oakfield, NY
Joel Darker
I have the standard 2 jet wand that came with the machine. What size jets would you guys recommend and will I lose alot of heat with more flow?
Thanks
breathe72
I run a 427.
Was using that same 2 jet wand you are using.
Called Greenie and life is swell.
Supersucker
I have a Spitfire 4.0, predecessor to your mount, 21hp Urai-J 4.5. I am running a glided Ti wand with 9 flow @ 500psi. Cleaner, drier, faster. Water temp approx the same, maybe a touch more, with much more 'delivered heat', that is more Btu's hitting the carpet. Also if you are using a live vac hose reel, stop it!
