Honda V-twin camshaft
Becker
Becker
Before I try I figure I will ask..
How is it removed?
Becker;
Pull the valve covers off both heads.
Pull the rocker arms and pushrods.
Remove the crankcase cover off the back of the engine.
Camshaft gear and cam is accessible.
Becker
Becker
Yeah. I have the cam gear exposed. Have the valve covers off.
So if I pull the push rods then the cam will just pull out?
Becker
Becker
Thanks for the help.
I loosened the rockers enough to move them aside. Pulled the push rods.
And the cam pulled right out.
I have a new cam and new carb on the way.
And yes. I will clean and reclean the inside of the block and replace filter before firing it up.
But the machine just flat died. So I'm sure all the f
Platic peices are in the bottom of the block.
Would be nice to get another 3k hrs out of it. Maybe more as it will be driving a propane heat unit.
3,000 is good service for the Honda engine.
Another 3,000 is very unlikely, without a complete rebuild.
Becker
Becker
Ok. To be honest. Another 1000 would be great. 1500 awesome.
But who knows. All else looks great. I've been great about oil changes. Engine is going on a propane unit. So less back pressure might help her along.
Found cam for 100.00. 10.00 shipping.
Worth the cost to see.
