- Joined
- Oct 7, 2006
- Messages
- 49,935
I noticed nobody gave any advice on how to get it out.
We've not totally lost our minds here.
Yet
Yet
Yet
that's not all that bad, Big Slim
No one mentions them cause they're one of those tools that gets bought, used once or twice and then gets buried in the corner of the garage with all the other useless tools
crevice tool isn't what you need, Joel.
4" to 6" hand tools work best on the most tenacious filtsoil
4" PMF enclosed jet (not "internal" jet) is a great one due to it's concentrated mega flush floodjet .
if you use a TM, be cautious of jet distortion though cause you may need to turn down the PSI for some carpet types like dense Saxony or cheap builders grade cut pile
After a good vac, (cause often it's pi55 poor housekeeping and not true filtsoil) we hammer it with strong butyl pre-sprays spiked with oxy, rub in some fels, add some "Florsheim" agitation and let it dwell
and hell yea we charge extra when it's severe and requires more than nuking ....and "hands and knees" work is needed
We also advise them whats needed to correct it by caulking at the floor and wall joints ...otherwise it will return
Mikey;
The worst cases are seen with families that cook a lot.
Volatile oils get mixed in the HVAC airflow and deposit on the filtering carpet.
Once these oils are oxidized, they become more difficult to remove.
We use our H.D. Preconditioner containing multiple solvents to remove them:
http://pet.com/zen/index.php?main_p...h_in_description=1&keyword=H.D.Preconditioner
Larry
Usually see it newer homes. hardly ever in older homes. To me it seems like we see it in houses that are wrapped Tyvek or similar product. House envelope is wrapped and doesn't breathe. Draft has no where to go but out the walls, around the heat ducts and crawl space access.
Don't overlook a key point in this thread: It WILL come back!
